NOTE:
(six shooter) - the signal wire is dedicated to the tps. the power wire is NOT on my 96. i had to round up a service manual today at a local dealer to verify.
so... ..... anyone with tps problems. t-tap into the power wire at the pcm and run a new one to the tps. cut the signal wire at the pcm and run a new one out to the tps. keep them out of the loom and run them in a new loom.
i used a 2 conductor shielded wire for running the new wires... .
i also added pig tails at the pcm and at the tps to check voltages while driving down the road.....
this solved my problem.
thanks to all for the help.....
scott
scott
