when i took my tps off the first time, i had a bracket on the outside that apparently has no function. it is almost L shaped and has 3 holes in it. 2 of the holes are for the tps bolts and the 3rd appears to be for a spring from the pic in the service manual. also, it shows the bracket in the manual to be behind the tps. mine is on the outside and has no spring attached. all of this was brought to my attention by RAMMIN' (thanks) when he asked about my return springs... . of which i don't know yet cause the rig is at the alternator shop while i'm out of town tomorrow. any comments on this bracket illflem... . i know you probably know this area well since you clean your tps every oil change... . thanks. scott.
