For those who have replaced their TPS with a potentiometer or are considering it here is what I am using and the results I get on the road.
The stock TPS is still in the truck but completely disconnected.
I ran a set of three wires from the PCM to the dash mounted pot which is a 1000 ohm, ten turn potentiometer with a 500 ohm fixed resister at each end.
I use a turn counting dial so I know exactly where the pot is set.
With the pot set at zero, a minimum signal voltage of 1. 2 volts is applied to the PCM. That results in a shift into OD at 30 mph and the TC will not lockup no matter how fast I go.
At the next setting which is one full turn on the pot, OD shifts at 32 mph and TC locks at 44.
At the other end of the potentiometer, turn #10, it shifts into OD at 62 mph and TC at 68.
I plan to run with it set at position #5 which shifts into OD at 45mph and TC lockup at 50. If I am towing a load, I use a vehicle speed controlled relay to delay the TC lockup.
The one drawback to this setup is that it prevents manual kickdown or downshift under load. I have overcome that by using a foot operated dimmer switch to open the TC circuit.
At the end of our summer "vacation" I'll have a better idea as to how I like it.
The biggest gain with this setup is that, unlike the stock TPS, it is reliable. If it is set for OD shift at 45 mph, that is what it does.
The only variable I have seen is a minor change as the vehicle comes up to operating temperature.
