Details here: TDR Privileges
Transmission is changing in and out of gear. With and without overdrive. Can some one tell me where it is located and what to do before I take it to the dealer?
The TPS is located on the left side of the engine near the front. Look for the throttle cable and the cruise cable. There is a cover (or something) covering it up and a 24 (too many) valve truck.
It sounds like you are having the same problem I had. My torque converter would lock and unlock going with or without cruise. Service Bulletins said ECM and PCM should be flashed. This corrected some problems I was having but local stealer finally replaced TPS under warranty and no more problems. It is on top left front of engine. Oo. Good luck
