Hello all,
I just got the track bar replaced under warranty. Now the steering wheel is off center about 10 degrees. Let me 'splain what I think is the cause and you tell me if I'm right or wrong. If the track bar is the tinyest bit longer or shorter than the old one, the axle will be located different laterally under the truck. Correct? Since the steering box, tie rods, drag link, etc. are all mounted relative to the frame, the different axle location will cause the steering knuckles to be turned a little bit. This will cause the driver to have to correct w/ the steering wheel. Your comments are appreciated.
