Its a fair question that I've also been trying to answer and you get opinions about all the choices being the best. Some go for OEM replacement. I think it's better to upgrade to a better design like the 2003 bar and eliminate the poor ball joint design. There's probably a reason Dodge changed the design. I went with the Lukes link as a tempory fix cause I did not want to spent the money and had not decide on what bar to get... I'm still undecided on what aftermarket one to go with.JoeMartin said:Ok I've also got the same thing going on here
I'm a new member to this site and just love what I'm reading.
I've got a 94 2500 4wd and finally at 95,000 the track bar is loose on the frame side so I'm also looking for info. Alls I do is haul a 24' Car trailer and plow a couple of driveway during the winter so am I better going with a Stock replacement from someone like NAPA?
How ofter do these things wear out?
I have Thuren's website info and I've also seen Darin mentioned.
Does someone have a website for them?
I also saw today SoilidSteel's website and they also have one listed.
I know a stock replacement is about 160. 00 what do the other's run?
Thanks Joe
I can tell you for sure you need to replace it (If you know its bad) if you want to avoid the "Death Wobble" many like me have experienced. That is the first thing to fix and its relatively easy. Any loose joint in the front end can cause it along with shocks. It sure rides better when every thing is tight and then you get spoiled by any play in the steering.
http://www.solidsteel.biz/ You must order from one of the approved vendors. This site is the only place (to my knowledge) that makes the DSS (Dodge Steering Stabilizer) which helps eliminate the steering box play. I think I'll get one. Supposed to help the slop in steering.
http://www.dtprofab.com/
http://www.thurenfabrication.com/
www.lukeslink.com For $66 you can rebuild the TB frame end like I did.
Dave
