Traction Control Springs
What is wheel width for 3rd gen
gears
i read in a post that some said the rear suspension needed to be at full droop. not sure if that changes the c-clip position or not. let me know what you do i am ordering these also.
Sounds like your pack retainer clip is in the way and they are a bear to remove and replace on the vehicle. I suggest call a spring builder to ask if its safe for removal. { probley not}.
That sounds like the clip alright. Holds the leafs together about midway between axle and mount point on frame.
