Trail-Eze Wind Deflector Adjustment setting?
Air Suspension #2
1995 Scotty CTD for sale in Reno, NV
I have that Trail-Eze Automatic wind Deflector and I was wondering if anyone has it and knows what hole to put the sprng jacks in... .
My Raptor Toyhauler has a sloped front end and I would estimate about 11' high. I have a short bed truck but have a 10" pin extender.
The mount has 3 holes on the bottom and like 5 or so on the deflector... . So where do any of you put yours after trial and error to get the wind to go just right?
heres a pic from the side on..... any help or settings you have on your trailers would be apreciated.
There are to many variables with the various TV/5th wheel combinations to come up with a set answer.
For a starting point I would connect the TV and 5th wheel making sure that they are on level ground. Pull a string from the center of the TV windshield (above the rear view mirror) to the top center of the 5th wheel. Adjust the position of the Trail-Eze so that it just touches the string.
The next step would be to clean to front of the RV. After a trip look to see how many and where the bugs are located. Then move the Trail-Eze up/down in increments each time checking the “bug” pattern, after you establish the “minimum” bug location that would be as good as you can get. I think that it is a trial and luck operation.
Let us know if this helps and what luck you have.
