That's a lot of meaningless gobblygook or, take your choice, baloney. If you only touch your brake pedal sufficient to activate brake lights you get no braking. You'll have to press the manual override enough to initiate trailer braking. That's not different than a BrakeSmart or MaxBrake.
If I'm floating down a long grade using the exhaust brake function to hold truck and trailer back and want to apply trailer brakes only it is very easy to reach over and gently press the red slider button on the side of my Brakesmart down to move the internal rheostat a little to add trailer braking to order, independent of my service brake pedal. The operating range of the rheostat makes it easy to manually apply trailer brakes very gently or to lock all four if slammed to the bottom of it's travel.
As usual your letting your own opinion cloud facts. Its VERY clear you have never tried what I am describing or you wouldn't be making false statements. If you actually understood how an inertial brake controller worked again you wouldn't be making those statements. . so here goes.
When you apply your service brakes they send a signal to the trailer brake controller that you are braking, not how much you are braking just that you are braking, so the signal to the controller is the same at 0. 1% or 100% braking. The inertial controller then uses its own inertial sensor to brake the trailer proportionately to the rate of
deceleration of the truck. . so if your decelerating from the exhaust brake and touch the brake pedal to activate the trailer brake controller it will sense the
deceleration rate and apply trailer brakes to match the rate of deceleration form the exhaust brake without having to either apply the service brakes or grab the manual control lever on the controller so you can focus your attention on driving and not manually braking.
So how do I know that your just randomly bashing something of which you very obviously have no clue? Because my brake controller has a digital readout of the voltage being applied to the trailer brakes, and guess what you can watch it brake harder with the exhaust brake.
If you are running empty or pulling a light trailer you will apply less pressure on your service brake pedal and get greater stopping power than when pulling a heavy load. You the driver compensate for the lighter load with your right foot. It works as if the trailer knows what you want.
That's all fine and dandy until you have to make an emergency stop and lock up the trailer brakes from a full service brake application. But let me guess you have never had to make an emergency stop with a trailer? (This is where you tell some anecdote about how your vast experience has taught you how to predict the unpredictable. )
I have no doubt that the Brake Smart and Max Brake are great controllers, and if I didn't have an exhaust brake I would probably consider one. But for the exhaust brake application I do not see them being superior. They are great for mimicking the
braking force of the truck, but that's not what you want with an exhaust brake, you want to mimic the
deceleration force. When I first heard about them I did a great deal of research, and I don't think that a good proportional (Inertial) brake controller can be beat for use with an exhaust brake.
