We have a couple of box trailers we use at work, both about 30 feet or so. I redid the lighting on them with using LED lighting from Grote and Maxxima. Looks real good at night. The trailers, like most, do not have backup lights nor do they have separate turn indicators, and I would like to add them. Especially turn indicators on the sides (like buses and semi trailers). It is impossible to change lanes in traffic because peopl can't see your intentions and when they do they won't let you over anyhow. The trailers both have the 7 pin harness, is there an easy way to get this to happen? If I just use the L/R combo brake & Turn, then the indicators will also light up with the brake lights. And there is no lead to the harness for backup, so I guess a switch is the only option for that, and add another 3 or four wire plug??
Any ideas??
Kev
Any ideas??
Kev
