Trailer Plug in BED
Low Railroad Overpasses and Tall Trucks/RVs = Destruction
HELP!! King pin stuck in hitch
Just getting back to TDR after long absence. Had a 94 5. 9 5speed 3500 DRW. SOLD it like a dummy. Now own a 2012, 6. 7, 6 speed manual , 3500 DRW Regular cab.
Looking for a real Plug and Play trailer harness for inside the bed plug. I have a receiver hitch and trailer plug on the bumper. Just want the T type , with a male and female T that plugs into the truck trailer wiring harness , with a 6-8 foot long extension with receptacle attached(already wired) to install in the bed for trailer.
Would appreciate any specific info , Maker / Brand , Part numbers , where to buy .
many thanks and looking forward to making new connections at TDR .
Be aware that the "plug and play" harnesses for the 4th generation trucks use the same 7-pin connector at the bumper end as the Fords and GMs. I made the mistake of buying one with a Dodge connector where it taps into the factory 7-pin connector - it didn't work on my 2011!!
Rusty
I agree with Harvey, I've used etrailer.com for a lot of items over the past few years... . and purchased the exact kit your asking for. for several other vehicles, all were reasonable in price and installed correctly. .
Go to the dealer and get the part you need. I ordered my truck and got the harness from the dealer. Of course I had to have it installed. Just plugged in to the wiring under the bed by the bumper. Tok longer to drill the hole than it did to install the harness.
This is what was on my Dad's invoice from Dave Smith in Kellog, Idaho. They did the install. 2317 CPA C/R 7 pin wiring $40. 00 Tech (S) 4415 NMP56000
Called my local dealer , parts dude said that is some kind of aftermarket part number. He says Dodge does not have a plug and play in bed harness. Thanks anyway
I'm still looking... ...
That is what I get for ASSUMING!
He did say the one in the bed is not as thigh as the factory plug in.
I just hang my cord over the tailgate and plug it in. I do put a piece of blue tape along the top edge of the tailgate to protect the paint.
Check out Harvey's post.
E-trailer is my source for most of my needs. I picked up a plug and play in bed harness from them 2 yrs. back
Good Luck
I have a 2001 with the factory 7 pole plug on the receiver. Will this mopar harness mentioned above work on my rig? I see that it was for a 2012 in the add. Also how long is this mopar harness?
The 4th generation trucks use the same connector configuration on the back of the factory 7-pin plug as Ford and GM. Earlier Dodge trucks used a different connector. etrailer and others have harnesses available for the pre-4th generation trucks, but they are different than the 4th generation harnesses because of this connector configuration difference.
Rusty
RustyJC has it right as below
Rusty
BARGMAN Part # 51-97-410 is what you want for a 2012 harness and PROBABLY 2010-2013 (but do your own research)
I bought mine on Ebay for $80 including shipping from ecustomhitch seller, pricey , but not too bad when you consider true plug and play , installed in 30 min. and no hassle , no soldering , nothing else needed , and a neat install
Evidently Bargman rebrands these harness' and sells them to Reese, Hidden Hitch, and Draw Tite as I found they sell em too , with the SAME PART NUMBER as Bargman.
Thanks for the suggestions from members here , and hope this may help others if they need a harness. dullpain
Rusty
