2nd Gen Non-Engine/Transmission Trailer tail lights
My truck does not have does not have any voltage on the pin for the
"running lamps" . It has the original wiring setup. The red wire with a black tracer is connected to the pin on the female 7 pin plug. The wire has continuity all the way up to plug that has many wires going into and out of the other side. This plug is at fire wall area just above the frame rail. I checked at this connector pins on female side for voltage none present. Then the wiring harness splits several ways. I have tried to chase thru the haynes
manual with out any luck. Does anybody know where this wire ends? Is it fused somewhere or connected to a relay? My tail lights on the truck work
fine and there are no wires spliced off of the tail lights going to the trailer connector. Any feedback is apprecited Thanks
2001 quad cad 4x4 3/4 ton auto, edge w/ attitude, BD lift pump
Have you had a trailer hooked up to this truck before ? It is the PCM that needs to be reset by the dealer. It's a stupid system .
I had a similar problem a couple weeks ago. My problem ended up being a blown fuse. I found a bare wire on my trailer that shorted, I guess. Took out the trailer light bulb, and apparently the fuse.
Brent
I don't know when Dodge started running the lights through the PCM. On my 01. 5 the trailer lights are on a separate relay and fuse circut and does not go through the PCM.
Stan
To all that replied to my post, thanks alot, It was in fact the
40 amp trailer fuse in the power module. I have a FSM on order for this truck.
My next one to go after is the electric door locks. It appears that the 10 amp
fuse has power on both on both sides when measured from ground. I pulled
the door panel and ohmed out switches which seem to function correctly.
Unless some one has experienced this problem, I'll wait until I get good wiring
diagram so I can check continuity thru the harness. Or does it go thru some
unrelated, relay, fuse etc. Again thanks alot for all responses
01 2500 quadcab, 4x4 edge w/ attitude, BD lift pump.
90 250 reg cab 4x4 BD injectors, 16 cm turbo and genos' guages
