It's not always a cost issue...
Some travel trailers equipped from the factory with 15" wheels and tires (like mine) cannot accommodate anything larger. To do so would require extensive modifications to the travel trailer and possibly even moving the axles. This effectively prevents converting to LT tires and still maintain an adequate tire load carrying capacity. So ST tires are really the only option in this case. With that in mind, it then becomes a matter of trying to choose the best quality / highest load capacity ST tire and wheel combination. Currently Maxxis has a good overall reputation for their ST tires. Of course time will tell.
I've never yet had a tire blow on any of the travel trailers I've owned. This may partly be due to luck, but I never tow faster than 60 mph, am careful to regularly inspect the tires and monitor pressures real-time (with a TPMS), and all the travel trailers I've owned have weighed far less than the tire and axle load carrying capacities. In the case of my current travel trailer (an Arctic Fox 25R), the axle scale weight (not including hitch) is less than 7000 pounds when fully loaded and I'm using 4 each 225/75R15 load range E tires and appropriately rated wheels. This gives a total tire capacity of 11,320 pounds which is a large margin of safety.
Best regards,
John L.
John, Read my post #20.
george
