Trailer Wiring, Kenworth
Future of diesel- 4 major cities ban diesel engines
Traffic stop smoke test
So when I do that I would actually take that breaks the power put it on the inside parasites that does not Flash correct? I say that because Michael's already work so if I put it besides other than just one. Or should I just get rid of the Box 7pin RV that's already there got my new lighting off my bumper lights?
Yes, it does at times for sure. I think you are asking if you should try and tap into the existing plug on the cab or install a completely new RV 7 way??
If so then I would just install an RV 7 way back there and feed it with the tractor tail lights. Those trailer plugs are like women, have as many as you want if you can get away with it....
I will be AWOL for about an hour and a half, heading for home. Will check back in when I get to the house to see how you are making it.
Nevermind that confusion. I'll just get rid of the pins for each turn signal that's already there, and tap into my tractor bumper turn signals. There fore I should have brake and signals individually, finally.
Shouldn't be that hard. I apologize. My brain has been going nuts.
