I won't be pulling an RV, but I do have a dump trailer, and might hook up the power to the batteries that power the dump. Than again, I might not, and just put those batteries on a charger every once in a while.
So, I'm thinking I need a continuous duty solenoid for the 8 guage wire from the battery. Then I need a separate circuit breaker (modified reset?) and relay for each of the 7 wires to the trailer, a circuit breaker mounting bracket - and some kind of waterproof box to mount them all in. Does that sound about right? What should I use for the waterproof box?
I did just order a fifth wheel/goose neck wiring harness that plugs into the factory wiring. I think I can cut into that wiring with the relays and not have to cut the factory wiring any where.
