Details here: TDR Privileges
According to DTT Front tighten to 72inlbs back out 2 turns ( Bill K prefers the 1/4" hex key method or so I assume as when he took mine apart he knew I used a torque wrench & felt I ahd it a bit tight) which I have come to the conclusion is about 2-1/4 turns out. The rear is turned out 2-1/2- 3 turns. ( The rear should not require adjustment very often, as it is only used when you manually put it into 1 or use reverse. )
