Trans Cooler Lines
Coolant Draincock Problem
AutoMeter 3-Guage pod w/tweeter
Does anyone know how to seperate the trans cooler lines where the metal line attaches to the rubber line before it enters the cooler ?? I'm changing out my fluid for Amsoil ATF and want to get all the old stuff out. The line has some sort of plastic ring around it which I think has something to do with seperating the two. Any help is appreciated.
96,longbed,clubcab,driftwood,custom bumper,K & N Filter, Filter Engineering Remote Fuel Filter & Coolant Filter,Scotty Air,4" from KAT be gone,4" Dynomax race magnum
Just carefully squeeze the "ears" on the nylon insert and pull the line apart. This is one of the plastic connectors that have been widely discussed in the past. Before you put it back together make sure the nylon is in good shape.
Ron
'96 Club Cab 2500 4x4, 4:10LS, Camper/Tow package, Auto, BD Pressure Loc, Mystery Switch, TST 230/605, Cummins Chrome, Mag-Hytec rear and trans covers, Boost, Pyro and trans gauges, Optima Red Tops, All black. Tow 14k HitchHiker triple glide 5th Wheel. Also use 9. 5' Lance camper. NRA Life Member.
I was wondering that also. has anyone ever reinstalled the lines with compression fitings to get fid of the plastic ones?
95 club cab auto 2wd SONY 10 disc + RCA 9" tv/vcr + lost muffler + silencer ring + slid stock plate & k&N so far... !
On your 96 ram you might not have the fittings with the ears. You may need to buy the line tool to do the job. You can get it at a parts store you'll need an half inch one. Just ask for a a/c snap line fitting tool.
Is this the plastic connector which has the possibility of melting during high trans temp. Don't they have an upgrade for this which gets rid of the plastic?
1997 2500 4x4,Amsoil throughout,ready for more power
Always wondered where the notorous plastic fittings were. My '95 has steel flare fittings in that location. The truck was a demo and had 1200 miles on it when I bought it. Were the steel fittings stock in '95 or were they added later?
95' 25004X4,AT,Driftwood,Banks,Warn fender flairs and running boards(Play truck)95 3500,5 speed,driftwood,Banks&phscotty,34,000 GCVW apple and tractor hauler(work truck)
Thanks for the help. Got em loose & were filled up with Amsoil ATF.
Originally posted by sweetmonte:
I not sure when the switch over was, but you can switch from the plastic to the metel inserts.
Last dealership I talked to said they had done away with the metal inserts and now you have to buy the whole line replacement kit. Definitly pricey, so I left mine and just periodically check the condition of the fittings.
The metal insert fittings leak when used in place of the plastic ones, they are different id. best bet is to change the lines. the worst line for causing problems is the t/c out line, the one coming out of the front of the transmision. Someone told me that when you replace the quik coupler with a compresion fitting the line will crack from vibration.
Give me a call if you need anything.
2000 2500 long box 6 speed with everything but cab roof lights,Pyro, Boost, K&N, 4" exhaust, BD Brake, OEM nerf bars (best fit), 1 877 511-5599
