I think this weekend might be "be-kind-to-my-truck" weekend. Thinking of changing the fluid in my NV5600. I'd like to consider the filter from Geno's. A couple of questions:
How often do I have to change the filter? Will it plug up right away from the stuff that didn't drop-out in the fluid change? (IOW, how soon until I have to buy new oil again)?
I saw mentioned in another thread that the gaskets can cause problems. Are they just prone to leaking, or is the problem that they make it easy to warp the cover? What's the consensus, gaskets, or RTV?
Is there any reason the filter could be more problem than it's worth (price sure seems cheap enough)?
Also, (maybe stupid questions, but... ) how hard is it to re-fill the unit, and how do you check level? (No, I've never checked the top side for a dipstick or fill port, figure I'm better-off asking someone with experience, while I'm stuck here at work). The latest issue of the magazine used a fancy funnel set-up. Is this necessary, should I consider one of the EZ funnels (from Genos), or can I just pour carefully right from the bottles?
Thanks for your patience/help!
