trans help
Preventative Maintenance Brake Fluid Flush?
Curt Better Weigh
bigblock_doc
I'm getting a P0871 code, replaced the trans pressure switch with a new Mopar part.
Still does the same thing. Cel light comes on and trans goes from first and shifts to
forth at 16mph. I stop and clear the code and I can drive another 500 to 1500 miles
and it does it again. It mostly happens in stop and go traffic. Truck is loaded and I
always shift with the button. VB was replaced by dealer under recall, but it started after
that. Truck is stock, non ho. Also notice a rise in trans temp when this happens.
Well I guess no one has had this issue. Dealer wants $335 to diagnose the issue. No codes found, now they
want to crack open the pan and look inside. That's there words.
