Trans info on 1993 Escort
Anyone Ever Adopt A Shelter Dog? Need Advice
May be a Longshot? Software Engineer Looking for Employment...
Does anyone have access to a rebuild manual for a 1993 1. 9L Escort? I need some info on what's going on inside for troubleshooting purposes. The cars not worth the cost of buying the book. Just thought I would check. Thanks.
LoneRam
93 Ford Escort info
I have access (neighbor has one) to a Haynes or Chilton (can't remember which) that has the transmission information in it.
Do you want me to get it from him and fax you the pages or send them in the mail or ... ... ?
PM me if you need more detail
ford escort
I just got rid of a '95 Escort at 75,000 miles with the 1. 9 engine. The car ran perfect for 40,000 miles, then the timing belt slipped/broke, $350 not covered under warranty and 10,000 miles before the belt was supposed to be replaced under routine maintenance. At 60,000 miles the head gasket gave up along with the intake and exhaust gaskets, water pump, thermo, and oil pan gasket. $1150, also not covered under the extended warranty. Six weeks ago the engine swallowed a valve, repair bill at Ford $4300. The car was worth about the same as the repair bill so I never went back for it except to get my license plates, personal stuff, and the bike rack on the roof. All this for an economy car. I try to buy American but when Ford takes care of their customers the way I was, so long.
I now drive an '03 Jetta under warranty for a long time incl. oil changes, etc. at no cost.
93 Ford Escort info
Lone-Ram your mailbox is full so here is what I came up with:
The Chilton's manual does not show any or the internal working parts.
There is a Cutaway view that points at the major components, instructions on how to adjust the linkage and a section on how to remove and replace but nothing on how to fix/rebuild/repair.
Do you want any of it faxed to you ?
