Can't really tell if it's at the quick disconnect fitting (o-ring?) or the threaded fitting into the trans case. It's the line out with the temp fitting in a '95 47RH. Problem is that the "quick disconnect" is neither. Supposed to be finger pressure to pinch the 2 plastic release tabs, and then the line will pull out. Not happening, even using pliers to pinch down the tabs.
I want to take out the line to inspect/replace any sealing o-ring and to remove and teflon-tape the threaded fitting before wrenching that back into place. These QD tabs... I HATE THEM!!! This reminds me of when I had to deal with them on the fuel tank sender for the "faulty level unit" fix.
Any ideas for the tabs?
