trans. lines
UPDATE!! BY-PASS OIL FILTER=BETTER HURRY!
Pramature Ring & Pinion Failure?
I'm new to this so have patience.
I've had problems with the lines and fixed some things- got rid of the plastic fitings after one melted. I would like to have everything threaded together instead of clamps. Is the dodge kit threaded? A friend is milling a piece so I can have my temp sender and the stock sensor in the line out of the transmission.
I'm sure enjoying going through all the posts, and learning stuff too. Thanks.
95 Blue 2500 4x4,3. 54,33x12. 5x16. 5 tires,catless,BD trans. cooler,Pacbrake,gauges-trans. temp,boost, pyro;high power cam plate ?Bosch?slid forward,afc adjusted some
96 Alfa SeeYa 30RK
Hello Frank,
This is a very common failure
Dodge offer a complete replacement line set with all the fittings, that screws together.
I sell so many I have them in stock at all times.
Ted Jannetty, Owner President, Jannetty Racing Enterprises, Inc.
97 3500 4x4 club cab 5spd. RED, JRE custom power kit, JRE 4" exhaust
JRE 1/2 inch fuel system, Bosch 300 hp injectors, Prime loc,
Cummins chrome kit, US Gear 20% over drive, 3. 54 posi, Autometer
Ultralite 50lb. boost, and Pyrometer, BD exhaust brake.
Horton fan clutch
99 Ski-Doo 800 Formula III Pipes, reeds, studs and clutching 172 hp
99 Honda Forman 450 ES jet kit, pipe, lift kit, 27" Mud Runners
2001 Ski-Doo MXZ 800 X stock for now 140 hp
2000 TransAm Ram Air WS6 Flowmaster, K&N, Granatelli Mass air meter, LS1 Lid 370 hp
1973 Camaro Rally Sport Street Strip 850+ HP
I posted a way to fix that problem permanently using Dayco push-on hose and fittings. It cost me 25-30 dollars if I remember correctly. Do a search on this and you'll be amazed how many results it comes up with. I'd give you a link but I don't know how to.
J Case
'95 2500 4x4 Auto Reg Cab
Big Dick's 2inch lift
BD tc, vb, Pressure lock, and 4" exhaust.
K&N RE-0880 with 25-0880 prefilter
Custom Fuel Pump by Piers!!
POWERCHOKES BEWARE!!!!!
Thanks Ted. I should have said the mechanic that put in my BD cooler re-routed the lines so they go straight from the stock cooler back to the transmission. Is there any problems with too cool trans temps?(other than a delay in shift to OD + TC lockup -not much of a problem in S. Ca. )
96 Alfa SeeYa 30RK
