It seems possible that I have a transmission oil leak from the shifter on my NV5600. The dealership may have removed the shifter recently to get better access to the AC (dash removal) that was part of the blend door/recirc repairs last month. Assuming they did remove the shifter and now I have a leak, I am considering taking it back to the dealership for repair...
... UNLESS...
... it is an easy fix and does not require a gasket or something I don't have. Is it reasonable to remove the little semblance of a console (ST trim) and gain access to the shifter?? Could I then take the shifter off, clean, and reassemble with sealer?? If this is a simple job, I'd rather do it myself (and do it right) than take it back to the dealer and wait.
I've always had good service from the Franklin, TN dealership, but the 305/555 engines don't need much time in the service department...
... UNLESS...
