The bosses 2001 2500 with auto of corse the trans took a dump at 60k, his is a 4x4 and he took it to a trans shop here, this trans shop says they installed a heavy duty converter, and did the tricks with the valve body& line pressures, It seems strong but the part that don't seem right is that from a stop if you hold the go peddle to the floor the trans will not shift from first untill you let off a little. I was woundering if this was a norm with the upgrade. TIA Harv
