Anyone ever rebuild their own transmission?
So on my truck I dropped the pan and found broken snap ring. Assumed it was the snap ring in the overdrive unit. I was going to change the snap ring myself. I pulled the transfer case and od unit together because I couldn't separate them in the truck. I also found 4 of the 6 bolt holes on the od unit were broken. So I know the od unit housing is no good. Nothing I could do would separate the od from the transfer case. I wound up cutting off a bunch of the od unit before I could get it to separate. When I finally got it off. I found the retainer of the transfer case that centers the case in the od housing had diesntegrated and part of it cracked and falling apart and the disentegrated part was laying in the bottom of the area between the transfer case and the od unit. I started chipping the crap out off the transfer case and the screwdriver went right through the transfer case and all the fluid poured out so now I need either a transfer case or replace the front cover.
So while I'm contemplating this and reading stuff and watching videos. I was thinking of buying a reman od unit from cascade and now I'm wondering if I just pull the rest of the trans out and try and rebuild it myself. It was working ok before this but has 183,000 miles on it. Rebuilding doesn't look that difficult. Granted I've never done one before, I've only ever worked with motorcycle clutches and transmissions.
So anyone ever tackle a trans rebuild themselves?
