Thanks for the help
Thanks Paul Herioux what I have is a 4spd automatic in my 1992 D250 2wd. I took an overdrive( just overdrive not complete trans with 4x4 output shaft)off an 1996 47RH 4spd automatic 4wd and bolted on my 1992 4SPD automatic in place of the 2WD overdrive output shaft. when I put it in gear trans fluid came out weep hole I put RTV in weep hole seems fine . will the trans fluid still be ok at that level is my main concern. the level it has to reach to go back to the pan is the bearing. Thanks for your help . I am still building truck so won't know for sure till I finish how it will work out. Glad to see I'm not the only person with this problem. I talked with local dodge dealership they are clueless to anything other than direct replacement.
Thanks again your replys helped alot
