Trans temp probe in dipstick for automatics?
'01 Ram retaining water
test
Has anyone tried the transmission temperature probe which attaches to your automatic transmission dipstick?
If so, how do you like it? Is it accurate? Is there a difference in temperatures if mounted in the pan or cooler lines? Is it a pain to check your ATF with the probe attached?
Terry S. '98. 4 Quad Cab SLT, 2WD, 12 Valve - the correct number! 3. 54, AT, Trailer tow PKG, Camper PKG, OEM cab lights, 4" exhaust turndown, 5th W. Hitch, roll-top cover, tint, high performance K&N air filter, 265 Michelins and turbo silencer ring in tool box!
BOMB'n in Tacoma, WA.
19,700 miles - 5/21/00
<font color=teal>
See this thread for an answer :
Transmission Temp Sensor Placement
</font>
<font color=blue>
  • Eric D. Howard --- Baby BOMB'er! --- Member since April 8th, 2000
  • 2001 Dodge Ram 2500 HD 4x4 SLT Auto Reg cab Cummins Turbo Diesel 4. 10 gear ratio LT265/75R/16 tires
  • Patriot Blue Pearl Coat, Agate interior, Leather seats EVERY option - Coming next week Line-X Bedliner or Rhino
  • In the VERY near future Power Edge Box, JRE 4" Exhaust, and Autometer Ultra-Lite Boost and Pyro Gauges
  • transmission soon to have a new Torque Converter and Valvebody good for 400HP!?! Horsepower mods being discussed - I'll just say I am upgrading something electronically.
</font>
<font color=#f7f7f7>
[This message has been edited by KatDiesel (edited 05-25-2000). ]
I originally had one of those dipstick sensors. I used bullet connectors so I could unplug it to get the dipstick out. You have to be carefull you don't break the wires with the cover thing on the end of the dipstick pushing them against the tube.
I got one of those add-a-drainplug things and put it in the pan next time I had it off and put a sensor there. Same temperature readings as the dipstick.
I just recently changed the transmission lines and put a sensor in there. Quite the difference between that and the pan, you get to watch the transmission fluid temp in real time.
"Roadrunner"-96 4X4 club cab-12v-auto-3. 54 gears-Amsoil bypass filter - all Amsoil fluids-trans filter-britebox-shelfit-DeeZee boards-Rhino liner-Rancho 5 speed shocks-Hellwig rear antisway & overload springs-Warn 12000 lb. winch-dual redtop optimas-combo gauge and trans. temp gauge in pillar mount-255/85R16 Kelly MSR tires-custom pinstriping- Walker muffler-Cummins mudflaps
