trans temp sensor DON'T DO THIS WAY
Intellitronix Problem
Pacbrake W/Autoloc Question?????
<font color=red> OUCH!,</font> Bill is your calender full on the 21st of April for a consultation? I need advice and a quick band adjustment. I also have a Mag pan to replace the oem.
Thanks,
Bob
01 Dodge Ram 4X4 QC
Sure Bob,i will fit you in, it seems we are giving an informal seminar, and Stefan is working on a little something for you guys that want to check out your Drag racing skills.
Bill
Just curious, is the location bad or was there something else wrong, I can't tell from the pictures. I have seen quite a few trucks with the sensor installed in the forward most port on the passenger side on a rounded surface.
Dave D
2001. 5 QC, LB, 4x4, Auto, 3. 54, Everything but Leather, Bright Silver Metallic, ARE K Series, Diprocal EGT, Boost and transmission Temp in an Autometer Dash Pod, Westin CPS Platinum Step Bars - Black on Stainless
Dave D,
As you can see, the sensor is sticking into the bore. There is an accumulator (piston) that has to move up and down in there!
Good pic Bill!
'94 3500 4x4, 209,000 miles, Never had a cat, Auto w/shift kit (thanks Dave G), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro gauges inplace of cupholder & Amsoil Air Oil & Bypass Filters & Lubes, AWOL intake boot (put the silencer ring after I pulled the boot-too loud!?!). NRA member. Blue Ribbon Coalition member.
"Warrantee? We don't need no stinking warrantee!"
Bill, I'll be there too. It sounds as if Mopar-muscle will be joining us as well.
Those pics remind me of what my Junior High Scool wood shop teacher once told the class: "No project is completely worthless, it can always be used as a bad example. " #ad
..... another good reason to change to the ATF cooler line with the integral temp. sensor port.
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
NRA Life (Patron) member
Bill, DRAG racing, you didn't say anything about drag racing. How long does it take to drive to Canada from here, hmmm... ... ... .....
I have to get even for Phoenix. Let's see, DD2's, a new trick box.
Fred Swanson
Co-Owner
Canyon State Components, LLC
www.canyonstatecomponents.com
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package, Tow Package, DTT's VB & TC
bill i just got a trans temp gauge where should i put the sending unit at.
Y2K 2500 4x4 ext. cab 8'bed nerf bars,Linex,xtang cover bug shield, husky liners,every option but leather and cab lights remote starter auto 3. 54 gears
98 grand caravan (for wife) 93 harley davidson fatboy
Bill,
What about those of us with a '95 auto that actually uses the temp port on the cooler line for actuating the overdrive? Is our only option to build a "T" shaped adapter for the 1/4" NPT fitting on the cooler line so that we can place a temp sensor there?
'95 2500 SLT ClubCab, automatic, 3. 54 LSD
bill, say it ain't so. i installed mine about 1000 miles ago in my '01 . the sensor came with the gauges i got from tst,,the instructions say to put it in the front servo test port,,i just went and took it out and put the plug back in,,,,the sensor dont have any scars but there is a small spot on it that is discolored. how can we tell if any damage was done? are there any symptons to look out for? please help!!! thanks
94 2500 4x4 SLT,auto,183,000 miles,3:54,brilliant blue/silver,tst 250/635 set full forward,star wheel wide open,air box ported,pump turned up 20%,k&n,gauges,cat gutted,
2001. 5 3500 4x4 q-cab slt,auto,6800 miles,3:55lsd,brite silver,tst power max 3 adjustable,3 gauges on the a-pillar,both have 12k hitches&15k's in the beds,30ft fourwinds 5er,(MY RAMS) http://albums.photopoint.com/j/AlbumIndex?u=1360183&a=10142301
Iceman
That probe was from Terry's truck, that is the first sensor i have actually seen that has gone through far enough to make contact with the 2nd gear servo spring. (ispro)
While i like to see the temp sensor in the cooler lines, 96-98 Dodge rams will accept the 98 transmission line as is no changes.
98 1/2 -2001 you must remove the one way flow valve that is located in the heat exchanger. 95 and earlier rams already have a temp sensor in the line, i have seen people that have teed off the existing temp sensor and develop late shifts into od.
For the 95 and earlier guys, i prefer to see the temp sensor in the pan. If that is not possible then you must use one of the pressure ports. Use the port in the middle, not the one up front for the 2nd gear servo.
Bill Kondolay
Diesel Transmission Technology
Bill K. ,
I really appreciate your knowledge and experience with Diesel RAM Auto Trannys and thank you for all the info I have been printing out from the TDR of your responses. I am making a library of Diesel stuff that I will be able to refer to for a long time.
My question to you is about the location of my trans temp sensor, and it's accuracy.
I have my sensor at the very end of my Trans Oil Dipstick. Accurate or Not??
Thanks for your response ,
Bob
Y2K Black 3500 ISB 4x4, 4:10 LSD,Auto,QC,SLT Laramie,"EZ", LB, Polished Stull Billet Grill & Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges,Rancho 9000's set at '1',Diamond Plated Tool Box, OEM U. R. Bedliner + other stuff.
Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
