trans temp ?
DTT gets a big NM welcome (ripped off)
Moog suspension parts
what is the normal operating transmission temp for the auto's ,,,,,,no pulling etc. ,,just normal driving ? i put gauges in a while back in my 01 and the temp will just hit the 140 deg. mark which is the lowest reading on the gauge and was just wandering if its correct
94 2500 4x4 SLT,auto,183,000 miles,3:54,brilliant blue/silver,tst 250/635 set full forward,star wheel wide open,air box ported,pump turned up 20%,k&n,gauges,cat gutted,
2001. 5 3500 4x4 q-cab slt,auto,6800 miles,3:55lsd,brite silver,tst power max 3 adjustable,3 gauges on the a-pillar,both have 12k hitches&15k's in the beds,30ft fourwinds 5er,(MY RAMS) http://albums.photopoint.com/j/AlbumIndex?u=1360183&a=10142301
Sounds like mine.
When in lock up, my gauge will hover right at 150 degrees. I have been lead to believe that this is nominal. I do have a DTT TC and VB and a maghytech pan. The highest I've ever seen it is around 180 in stop and go.
Keep cool;
Josiah
YP of SETDR
Y2K 2500, 4X4, Auto, Quad Cab, SWB, 4. 10, Black. Hot Power Edge, DTT TC and VB, Line-X, PE Roll top bed cover, Stainless add-ons. Jardine 4".
<font color=blue>Since your gauge starts at 140&deg; then you will rarely see it much above that while cruising down the highway. Which is why I got the 100° to 240° transmission temp gauge. In stop and go traffic I can get it up to between 170° and 180°, and then I can get it upto 200° and a lil over when "playing around" with burnouts etc. <font size=-2>
[This message has been edited by KatDiesel (Eric Howard) (edited 02-21-2001). ]
My trans temp, sender located in hot line, normally runs between 140-160. It will go up to 260 when towing up a steep hill where there are a lot of turns and you can't get over 25 mph. I buried the temp gauge at 350 when I suddenly started losing power even though the engine was at 2500 rpm. Then I saw a lot of smoke, it was from the transmission fluid on the exhaust pipe. Factory rubber hose that connects the hot line to the heat exchanger blew. Changed all the fluid, and luckily the trans is still OK. Still shifts like it did before the hose blew and still doesn't slip at WOT. My gauge is 140 to 350 degrees.
1996 3500 Clubcab SLT, auto, 4. 10 limited-slip, TST #5, 370s, AFC spring kit, Psychotty, Dunrite converter, Trans-Go, DiPricol EGT, boost & trans temp. gauges, 9 ft. aluminum flatbed and tool boxes with Venco dump. Custom front bumper, Hadley air horn, PowerVision mirrors & 4" Stack Exhaust.
My trans temp sending unit is on the end of my dipstick! I never have been over 200 degrees uder load in the middle of summer floored!
Bob in Sacramento, Y2K Black 3500 ISB 4x4 4:10 LSD,Auto,QC,SLT Laramie, Slightly BOMBED :) LB, Polished Stull Billet Grill & Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges,Rancho 9000's set at '1',Diamond Plated Tool Box, OEM U. R. Bedliner + other stuff.
Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
My temps rarely get above 100 degrees measured in the pan (Mag Hytec). Towing (13,500lbs) I saw it get just above 170 once. I understand that the best place to monitor the real temp is in the line leaving the transmission for the cooler? How are folks tapping a sending unit in the line?
'95, 2500, 4X4, ext cab, white, 3. 54 rear end, auto transmission
Griffin Radiator, Banks Power Pak, Kondolay TC, Kondolay VB, 16cm Turbo, 4" exhaust, Horton Fan, Bosch 215, BD Governor Springs, Brite Box, Mag Hytec transmission Pan, aux transmission Cooler, Bully Dog Propane, Gutless Kitty, Wiley Coyote strapped to my grill
Originally posted by BigCarl64:
Did you ever get that HX40 installed? Just wondering how the bottem end is working that allows you to do burnouts?
<font color=blue>
No the HX40 is still not "on" the truck. It has been prepped by Majestic Turbo, and is ready to go one. I wanted to "further" upgrade my transmission, and make sure my fuel system is stable (lift pump etc) before I add any more power. If I want some fun I punch up the PE on Level III. I'll post as soon as its on, along with the DDIII's, ATS Manny, and also hoping by then the Edge COMP box (PE & EZ in one box) is out so I can change to that. Its kind of a "hurry up and wait" kinda thing. Also the purchase of that 71 Challenger kinda took "priority" so haven't concentrated on the truck recently.
Originally posted by NDRamrod:
Kat what kind of guage and where did you get it?? I am thinking of a couple isspros. boost and temp but they start at 140
<font color=blue>
I have AutoMeter UltraLites series.
  • EGT 0° to 1600° - #4365
  • EGT Thermocouple - #5244
  • transmission temp 100° to 240° - #4357
  • Boost Gauge 0 to 35 PSI - #4304
  • Custom Boost 0 to 50 PSI - #4304SP
I need to take some more pictures of the truck's gauges, this picture doesn't do it justice (those of you that have seen it know what I mean). I got my gauges from Summit Racing, the 50lb boost gauge I had Autometer custom make and it can be ordered from JRE. <font size=-2>
[This message has been edited by KatDiesel (Eric Howard) (edited 02-22-2001). ]
Hey KATDIESEL, where did you run your lines from the gauges on the dash pod to the firewall? I don't really like the pillar pods but thought the dash pod looked O. K. but was wondering what to do with the wires and lines, thanks.
2001. 5 2500, QCAB, LB, K&N, WHITE/SILVER
I have the same dash pod, I ran my wires up past the A pillar and in the seam between the windshield and the dash. Some other guys drill a hole in the top of the dash under the pod and route the wires that way. I haven't decided yet if I want to stay with the dash pod I have, try out a dash pod that rides on top of the dash over the instrument cluster or see if I like an A pillar setup. The biggest draw backs of the 15002 are the glare/reflection on the windshield and a spot on the windshield that tends to stay frozen/refreeze unless you run your in cab heat pretty high.
Dave D
2001. 5 QC, LB, 4x4, Auto, 3. 54, Everything but Leather, Bright Silver Metallic, ARE K Series, Diprocal EGT, Boost and transmission Temp in an Autometer Dash Pod, Westin CPS Platinum Step Bars - Black on Stainless
I have Isspro EGT, Trans, and Boost gauges and wish I would've spent a little more money. The EGT gauge sometimes sticks and won't go below 30 (I can send it back to them and they'll fix)when engine is shut off. The transmission gauge starts at 140. But what irritates me most is that I have the three gauges in a pillar mount and the backlighting levels of all three are different. I can barely read the boost at night. You'd think Isspro would've figured that out.
2001 2500, QC, 4X2, SLT, 24 valve, ISB, A/T, Tow Pkg, Bright White Clear Coat
DTT VB, TQ, Smart Box, PacBrake, PowerEdge EZ Box, Bosch 275 Injectors, AutoMeter Triple Pillar,Isspro Gauges Pyro/Trans/Boost, Trans Cooler, Avitol Alarm, OEM Roof Lights, OEM Fog Lights, Flip/Tow Mirrors, Tint Windows, Cobra CB, Ram Polished 3rd Brake Light, Eyebrows, Pace Edwards Rolltop, Toro Bed Liner, Carr Super Hoop/Deluxe HoopII Steps, Husky Front/Rear Mats
1998 33. 5' Hitchiker Discovery Triple Slide 5th Wheel.
My Pix.com
