This weekend the wife and I decided to drive to the beach on saturday (dumb idea spent most of the day in traffic!). We were pretty much stuck for about 30 mins at one point and I noticed my transmission was up to 190 degrees, I have never seen it get that hot before. The engine was also up to around 210-215. At one point I also smelled a burning metal smell, not sure if it was my ram or someone else. We were sitting for a while, maybe the DPF did a regen, I remember seeing that you will get that burnt metal smell from a regen. Anywho, it quickly went away when we got past the trafic jam, and the engine started cooling down once I got moving again.
I have 2 questoins... 1) Is this normal after running for ~3 hours then being stuck in traffic? Once we got to the beach, we parked and I let her run till the trans fluid temp was down to 175 then shut her off. She was back to normal on the ride home. I was thinking about investing in a mag-hytec replacement pan for the trans at some point, 2) will this void/cause any issues with the warranty?
