I do have new 01. 5 with a/t 3. 55 rear end and 3000 miles on it. I plug PE Ez on engine, work great. Exhaust Temp. boost and trans gauges too are installed. I would like to install injectors (275 HP one or DD"s) with it, but I em worry about trans. My Q is. , if I change valve body or install shift kit, I know could be done without taking trans out, but what about rest of the seals, like pump seal and tc seal ? Will they blow up ? And will this upgrade work good without upgrading to lower stall TC ? And last Q. is, did somebody know the difference between BD pressureloc and BDtorqloc trans. control ? Look like they both are working on more pressure to lock up the TC. If so, which one will better serve me in my application. I em mostly pulling trailer around 8000 pounds and looking for little punch . But more power start to be addictive.
Thank you Milos
Thank you Milos
