hi guys i have a 2000 4x4 2500 truck and i have a problem with the trans the truck has 160k the trans wil not downshift to first gear on its own , i have to shift it manually and then it shifts ok. the trans was resently rebuilt by the trans shop in el monte ca. and they have not been able to figure out why this is , the reason for the rebuild was this exact problem , they have tried 4other valve bodys and no luck , so the end result is i start in second gear every time unless i manually shift. can someone please help!!!!!
