Transfer case confusion
Diesel Progress MUST READ
What does it mean when your truck is shipped to storage??
Hi,
Did search (perhaps imperfectly) several forums, but still have questions.
Nearing final decisions re. options on new truck order, I've run into one where my ignorance of these rigs is a problem. :confused:
The choice is between the electric-shift vs. manual transfer case.
The confusion arises from the fact that the labeling of the dash control (for the electric) does not precisely match that of the manual control.
On the dash unit, the settings are:
"N" (with indicator light)
"2WD"
"4Lock"
"4Lo"
On the manual unit, the settings are:
"4L"
"N"
"2H"
"4H"
Questions (Aside from "N", and "2WD" I am not certain how the terms are being used):
1. If "2WD"(electric shift) means 'normal' 2-wheel operation, why does the manual unit not use this same symbol, instead of "2H" (2-wheel high?,... . which implies that there might be a 2-wheel low)?
2. Since there are both "4 Lo" and "4 Lock" on the electric shift, . . which of these, if either, does "4L"(on the manual unit) indicate?
3. If "4L" (manual) equals "4 Lo"(electric), where is "4 H" on the electric unit?
4. If the answer (to 3. ) is "4 Lock",... how/why do the terms "lock" and "high" relate?
One factor in choosing between these units is the fact that dash contriol makes possible clear foot-space for the occasional center passenger, which we would like to have.
Other than this, what performance/dependability/durability reasons are there to prefer manual over electric, or vice-versa, ?
Rig and use: '07. 5 Ram Laramie quad-cab long-bed dually, 6. 7L CTD w/65RFE 6-speed auto, 3. 73 limited slip rear, 4WD, with 3-4000# (loaded) camper,... towing 4-8000# boat(s). Mostly Pacific NW, ... both flat and mountains.
Thanks for any help in understanding these units! :)
Everybody has their own preference. Some don't trust the electronics.
On our 04. 5, we have the electronic and use it a lot (rain and snow, off road). Personally, I prefer. I had a manual unit on a previous truck and, to me, the electronic works much better.
"2WD"
"4Lock"
"4Lo"
"4L"
"N"
"2H"
"4H"
N=N
2WD=2H
4Lock=4H
4Lo=4L
Of course since I don't own one it's only a logical guess.
When I was shopping for my 06 I found an electric shift but the ~$150 difference turn out to be a ~$500 difference. You had to do the bucket seats and console back then. I wanted the bench so went with the manual. Not sure what they are forcing on you now. Might want to double check on the manditory options to see what the cost really is.
