Have 2005 w / NV273 transfer case - wondering if there's any reason to change and replace fluid with anything other then the factory recommended ATF +4. Any brand recommendations? Thank you very much, Michael
Yes, the ATF is really a lousy t-case lubricant. Synchromesh is better, a mix of synchro-mesh and 50 wt oil is even better.
Gentlemen, thank you much for your input / response. I made several call to suppliers of rebuilt / remanufactured NV 273D transfer cases. I believe the folks that referenced sycro-mesh were referring to "Pennzoil Synchromesh". One of the guys I spoke with did mention Mobil One, but was referencing their version of ATF +4. I'm certain most of the responded I received (phone call) recommending ATF were understandably protecting themselves from any possible liability issues. Redline products did get high marks from quality and effectiveness. Wish I could talk to one of the engineers that helped design this gear box. Also, wonder what the guys running the Baja 1000 use. Thanks again gentlemen.
There is a pump in the TC that lubricates the chain.
Dodge did not spec the fluid nor did they change the recomendation from the mfg.The nv transfercases are used by other oems as well and I have not seen other fluids recommended by any of them
There is a pump in the TC that lubricates the chain. It is designed for ATF+4 and while many of us would like to find a suitable fluid that will provide better lubriacation and longevity for the TC, it seems as if using something with a hogher viscosity might well LESSEN longevity and lubrication of the chain due to the design of the pump needing a lower viscosity fluid. *That being said, TDR member CKelley does in fact run a fleet of trucks using some sort of blend that he has come up with.
At the risk of sounding the fool can you elaborate on "Synchromesh"? Getting ready to swap over to Redline Oil and will do the transfer case at the same time,,.
Also, Mobil Delvac synthetic 50wt transmission fluid is used to quieten the G56 when a single mass flywheel has replaced the DMF. It works great in my G56, but due to this fact is why I plan to go to the 50wt in my transfer case so I don't have three different oils to buy to service my drive train. Now only if I could get away with using it in the front/rear diff's I'd only have to buy one kind of oil.Northfork, Synchromesh oil is what New Venture used in the NV5600-6speed gearbox that pre dated our G-56 transmissions. It is about a 30wt viscosity but from what I know, it is designed to be run in a standard transmission. I had it for a while in my G-56 and it performed well. I have the Delvac 50wt in there now and mine is a little stiff on cold mornings. I have it in there because that is the weight of oil Mercedes originally specified for the G-56.
Talked with my michanic friend who races these trucks - said he uses ATF +4.
Racing is racing, towing is towing. Like a lot of things, what works fine in one instance is not always the best in another.
