My truck worked harder there than towing my trailer on the hiway. This in my case proven with gauges and fluid discoloration
How does that even compare? What gauges? What was being measured? What was the time factor? What was the distance? There is about 1/3 enough info there to even begin a discussion.
How do you quantify "worked harder" comparing an 8k truck running a couple hundred miles to a tow rig at +20k for thousands of miles? This is knowing full well that a race rig is getting a fluid change for the next event, whereas a tow rig is on schedule to maximize the maintenance intervals. I can run ATF in a diff, as light as grease and oil as possible in all lube points to chase thousandths of a second when it only runs 10 miles every other weekend and it is all getting changed and\or rebuilt before the next event. Not doing the same thing in my tow vehicle, nor would anyone else with a modicum of knowledge.
Racing is racing, towing is towing; there ARE many differences. "I race my truck and use ATF" and "This in my case proven with gauges and fluid discoloration" is meaningless without context.
