Below are the instructions from replacement of rear seal on transfer case - anyway to get away without the specialty tools??? I will find a way to get them if I need to, but I am about 70 miles from the city, so I wanted to get everything I need today, so I won't have to drive in tomorrow.
Thanks for any help. Charles
Rear Retainer Bushing and Seal
REMOVAL
Raise and support vehicle.
Remove rear propeller shaft.
Using a suitable pry tool or slide-hammer mounted screw, remove the rear retainer seal.
Using Remover 8158, remove bushing from rear retainer.
INSTALLATION
Clean fluid residue from sealing surface and inspect for defects.
Position replacement bushing in rear retainer with fluid port in bushing aligned with slot in housing.
Using Installer 8157, drive bushing into housing until installer seats against case.
Using Installer D-163, install seal in rear retainer (Fig. 16).
Install propeller shaft.
Verify proper fluid level.
Lower vehicle.
REMOVAL
INSTALLATION
Lower vehicle.
