transfer case shifter? and tail housing ?
4WD Light Not Working
HELP!!! 3200 spring problem
how do i tell if i have a gated transfer case shifter?
also i just seperated the getrag from the transfer case
and it had some oil in it is this normal?
lastly i am going to convert my get rag to nv4500
do i need to get the cast iron tailhousing?
truck is a 93 w250
thanks
Gated ones have to be moved sideways to get into 4lo. Non gated go in a straight line.
A little oil in the intermediate housing is not too bad. Just means the seals were leaking a little. Can you tell if it is from the t-case or transmission? Either way I would put a new seal on the t-case input. Unless you turn the coupler down you will have to remove the seal on the back of the NV4500. I used a double seal on the input of my t-case to hopefully prevent contamination. So far so good.
Unless you really plan on abusing the truck, you won't need the cast iron housing.
i just dropped off the transmission and coupler at
my machinists house so he can turn down the
coupler . i do not plan on beating on my truck
but i do use the 4-wheel drive and do tow some
