I call the 2nd Gen Dodge's front axle a fake Dana 60 because it lacks everything that ever made the Dana 60 the legendary front axle it was except for the center section (carrier). There is alot more to a front axle than that.
Gone are the much stronger and more durable kingpins, replaced as a cost-saving move by stinkin' balljoints which are fine for cars and 1/2 ton pickups, but not HD pickups.
Gone are serviceable tapered roller wheel bearings. Again, a penny pinching move by DC that ends up costing owners many times more money to replace the weaker and less durable unit hub and bearings.
Gone are the ultra-reliable and easily serviced lockout hubs with their true free-wheeling ability. Replaced by a complex vacuum operated CAD (central axle disconnect) that will let you down when need it worst and also turns one side of your front axle 100% of the time causing excess wear and sucking more fuel.
It gets worse: The axle housing is significantly weakened by the CAD assembly. Given the weight of the Cummins and the weight of my snowplow, that is a very bad thing.
Inside, again due to the misconceived CAD unit, you will find small, Dana 44 inner shafts! NOT 1. 5" dana 60 shafts! The passenger side wimpy shaft has a weak sliding collar to join the TWO pieces together. Yeah, a smaller diameter two-piece shaft to replace a beefier one-piece... How is that acceptable? An assembly is only as strong as it's weakest component. This abomination has nothing but weak components!
So go ahead, crank that torque monster Cummins up. Install big tires. Get into some rough offroad situation and watch that front axle disintegrate...
All in all, it is the most undesirable, weakest Dana 60 front axle ever conceived or built and is not even worthy of the name.
DC engineers stuck their heads even farther up their backsides to dream up the nightmare we all affectionately know so well as the "Dodge Death Wobble".
There will be all kinds of guys try to tell you how much better a coil spring suspension works, but in the case of a non-desert racer or non-rockcrawler that is total bull. Especially when it eats tires, parts, and thousands of dollars as quickly as these do.
K. I. S. S. > Keep It Simple Stupid. This fundamental engineering concept along with "Don't 'fix' what isn't broke" should be tatooted across the foreheads of the DC engineers responsible for this junk, right before they are fired and kicked out the door!
Front leaf springs forever!
cro-magnum: Your 1st gen Dana 60 is the real deal. Dodge has long used goofy unit bearings and hubs on some models, and I have always been a Chevy man, so I don't know what your Dodge 1st gen front has for wheel bearings and hubs for sure. I do know that you can easily interchange the beefy chevy dana 60 into a 1st gen. ifyou needed to or if it provided better hubs and bearings. The chevys have excellent 35-spline inner shafts.
