Details here: TDR Privileges
It's simple. I took the fill plug out first (to make sure I could get it off) then I drained it. Once empty I filled it with clean ATF 4. Didn't take long at all. Just don't over tighten the plugs and you'll be fine.
Just like JValdez said. It's easy. Take the bottom plug out to drain the oil. Reinstall the plug. Remove the top one and fill to overflow with ATF. I use a suction gun to get oil into the fill hole.
