Transfer Flow Tanks
Pillar mount gauges disrupt view???
Governor kit (Feel the Power!)
I have been using my new 98 gal in bed tank with transfer flows system for the last week and I love it. It was easy to install (7 hours me and 1 hour strong friend) and works like advertised. I fill both tanks after install and after the truck tank used about 8-9 gallons pump turns on and puts about 3-4 gallons in truck tank from bed tank-no need to watch gauges or do anything but fill up both tanks when low-truck gauge reads status of both tanks-the system keeps both tanks at appx the same level so this works-the computerized control panel tells you how much fuel is in each tank and what the total is and the system status. Two thumbs up.
1996-350 tst #5 plate, K&N air filter,Primeloc fuel filter kit,4" exhaust,Purodyne bypass oil fiter system, bigger injectors,b&m trans pan,Amsoil all around,temp gauges out the wazzo,much trans work,double tow 33' 5th wheel and 12' trailer w/motorcycle(Honda Valkyarie Interstate)Also have 1999-250-stock.
Installing Transfer-Flow 98 gal. bed tank, governor spring kit(BD), and Bill Kodalay's TC on 96 dualie.
