I made a trip up to Montana this week. Everything was running fine until I hit Sheriden, WY and my truck began to struggle pulling grades (I had a single gooseneck trailer on board - 6500# for the trailer) Typically I run in 6th gear and drop down to 5th when required. Started to slow going up a hill, pull down into 5th and the power disappears. I pull the hill slowly (felt like I was in my 93
). I got to Helena and went by Summit Dodge. Explain the situation - Truck runs strong, pulls hard to 2400-2700 rpm then rolls over. They reflash the computer saying there was an update for stumbling. The truck ran very stout after that and my mileage shot through the roof (for a 600, I was seeing 19. 4 on the overhead and 20. 4 hand calculated!)
I drove for 12 hours, dropped down through Yellowstone and head south towards Rawlins. As soon as I hit the interstate I begin to have the same problems. Any WOT over 2500 results in nothing. I went by the Dodge Dealership in Laramie - Avoid these guys at all cost. Based on the thought process of the service manager I would be horrified to leave anything in his hands.
I pulled over, popped both negative battery cables off, cranked the key (as I was told this clears the memory of the computer) hook back up the battery and take off. Problem solved. Truck once again runs very strong, mileage is way up (I went from Laramie to Amarillo on 1 fuel up - avg mpg 18. 6 @ 75-80mph). I get on the other side of Amarillo and SAME situation - right at 12 hours of drive time. No power to pull hills. Rinse wash repeat. I unhook the batteries and go through everything once again. Pull out and the truck once again is back up to snuff. Park for the night, hit it again at 6 this morning and wheel home. Approx. 150 miles from home, same problem
I call up Dodge and they mention the transfer pump, possibly an injection pump. The mileage is still up in the truck, no power after 2500rpm and it begins to smoke like a 12v past 2500rpm.
Anybody had similar experience? I thought about everything from wastegate sticking to fuel filter. Summit Dodge ran test on everything, flow was good, pressure was up, no block in the fuel lines.
I just hit 70,000 miles if that helps.
