Engine/Transmission (1998.5 - 2002) Transfer pump
Engine/Transmission (1998.5 - 2002) taking off in second gear?
Engine/Transmission (1998.5 - 2002) quadzilla?
With all the lift pump problems, I would highly encourage those of us without a FP gauge to check their 01 & 02 before the warranty goes out. I was driving the company 01 Wednesday for the first time in a while. I felt a stumble during light acceleration going 30-35. When I got on the I again I started checking it further. It would pull moderate hills in OD locked up with the pedal to the floor. When I hit the same hills at low enough speed to kick down to drive the truck would "skip". The tach would be erratic jumping a click at a time. I suspected the lift pump right away. Having experienced the Dodge dealer's brilliant staff before, I decided to change the FF before calling them.
Ended up having to tow it in because I could not get any fuel back in the canister. At least the truck still had three months warranty left at 72K miles. A mechanic friend said he had seen this several times with 24Vs where they seem to run OK under normal load with the lift pump dead until you break the vacuum of the injection pump.
Good luck finding those dead pumps at Dodge's expense.
I just replaced mine a week ago at 43,000. Im going to have to cough it up and by a Fass or Rasp system. I love this truck but its got some pore Enginering problems .
A couple of friends of mine (use to work with them at a different job) now work at the local Dodge dealer, and when they run into a truck that they can't get started, and they know that it is a roasted LP, they do not change it. They know that a bad LP can (will) lead to premature failure of the VP44. All they do is put an air duster and wrap it up with a rag into the filler neck to the tank and pressurize the tank to start the truck.
They are told unless they are specifically instructed to change the pump (even for warranty) to ignore the problem. Great management techniques.
They are a very poor design, remember, pumps work better when they push, not pull.
-Rich
