What I'm planning to do to increase fuel capacity while towing is installing a 27 gallon Tempo fuel tank. This tank is like a 6 gallon plastic boat tank with a built in gauge and a quick plug in fitting for the fuel line. The fuel line will run into a filter, then a small electric fuel pump, then to an anti-syphon valve and then into a T fitting installed on the main tank rubber vent line.
Does anyone have a recommendation as to an inexpensive electric, low volume (25 to 35GPH), fuel pump that will lift a maximum of 3' and run dry with no damage. Thanks
Stan
2001 2500 SLT+ Quad Cab, 6 speed, ETH, 4X4, LWB, 3. 54 LSD Trailer Tow, Camper Special, 241HD, Tow Mirrors, Bright White, Line-X Bedliner, Putco Boss SS running boards, A. R. E. K Series Truck Cap, Reese Titan V Hitch, 2WD Low, DD 4" exhaust, BD exhaust brake, Isspro Boost and EGT gauges, Mag-Hytec rear cover with Amsoil Series 2000 75W-90 synthetic, Amsoil Dual-Remote Cummins Oil Filtration System (full-flow & by-pass); Amsoil 2 Stage Air Filter
Stan
