Reb. B said:
okay rammer, transgo 101. lol. u dril a larger hole for a 1-2 shift firmness, u drill a larger hole on some for 2-3 shift firmness, u enlarge a hole in the small plate (with three bolts in it) next to the shifter arm it should be . 85 and u enlarge it to. 100 to . 125. I usually go . 100 to . 115 size hole. This is where u increase lock up pressure, firmness and hold power, . . not line pressure. Line pressure can be dangerous to play with. U can get external leaks as well as INternal leaks. the kit comes with differentspring for max shift speed, new manual valve, increase lube/converter flow, and a different spring that helps increase line pressure slightly. the kit has a couple other little helper in it as well. The converter overflowing could also be poor atf as well. I always run Mercon V and Lube guard with the ahoba bean.
