My uncle has a 2003 2500 auto 4x4 that is acting up when shifting into 3rd gear. It usually happens around 30 mph. When shifting into 3rd it kicks out of gear and you have to let out of it to get it to engage again. If you shift it manually it works fine and usually if you keep into fairly hard it will be OK. He said it has been getting worse. It does not seem to slip and other shifts are OK. The only modification it has is I think a superhips or some kind of mild programmer which he removed with no change. The trans is original as far as I know with 160,000 miles on the truck. If it has ever been serviced I would say it has been awhile although the fluid looks and smells OK. Also no codes when I checked it.
Thanks for any help,
Matt
Matt
