One of the things as I re read these threads, do we KNOW what "too hot" at the crossover port is from a transmission guy? We know what we have read about 200+ but is that in the crossover port or at the pan?
I think the difference in temp between the crossover port and the pan can be significant. 220 in the pan could be horribly too hot, but 220 at the crossover port could be well within llimits(whatever within limits means)
I am going to monitor both the crossover and pan to see what the difference is. I am also going to take the one way check valve out of the transmission lube circuit for better fluid flow (which means that I HAVE to idle my stock transmission in NEUTRAL for 40 seconds to fully charge the TC and lube circuit on the first start in the morning or if it has been sitting for an extended period of time). Not make any other changes and see what that gives as far as crossover temps and pan temps.
Has anyone done a Horton clutch or an electric full radiator fan? If so how did that effect your water, transmission, intake manifold air temps? What temp setting did the fan kick in at?
Really courious,
Bob Weis
Really courious,
Bob Weis
