transmission cooler line questions
DD clutch from a 5-spd work in 6-spd??
Synthetic Oil Change
Which line is the return, and which is the outgoing?? Need to build a new (or modify old) outgoing line for the transmission temp sending unit.
Outgoing (the hotter of the two) is the front one - closer to the engine. You can see it here:
You can see the crimp connector where it transitions to rubber - this was the result of the recall DC issued about breaking the trans cooler due to vibration.
I purchased a modified line from Mass Diesel that he cut, flared, and installed a Tee fitting for a sender. Works well.
-Tom
