My transmission lines are leeking,,they wore through both lines that clip together behind the engine oil pan.
I can get replacements from Dodge,,but they need a few extra fittings for the new style line.
Instead. i want to add a secondary spin on filter attached to the frame next to the transmission. .
I was hoping someone here that has done the same thing would have the correct size for the fittings that enter the transmission as well the ones that go into the engine mounted cooler. .
I plan on using 37 dgree fittings for the hydraulic hoses and the nipples in the cooler and transmission.
I realise i could just use barbed fittings,,but these seem a beter idea for future servicing.
So if anyone has the right sizes for the NPT ports i would greatly appreciate it,,,save a lot of downtime.
Thanks all
Thanks all
