Transmission cooler lines
Mechanical vs Electrical oil pressure gauge?
check this out
Does anyone know if the trans cooler line with the rubber section is to the cooler or from the cooler. I think it is going to the cooler but want to make sure before i tear it apart to put in sending unit fitting. :confused:
mike
Can you tell us what is involved in putting the sender in the cooler line? I have mine in one of the test ports and I know its not that accurate.
Ok thanks for the info. I think it would be as easy as cutting the section of rubber line and installing a double barb fitting with a 1/8 inch fpt port. Moose00, a place right over here in mass also has those for $75 i think it is called mass diesel or something. OH by the way hows everything in watertown?i used to live in woodbury and grew up in monroe. Thanks again,
mike
Yes, a lot of the Local TDR guys say great things about Mass Diesel. Things are OK here in Watertown, by the Woodbury border, as long as y9ou plan on using your cell phone in Woodbury. :)
