the metal line that connects from the back of the engine coolant inlet to the back of the engine mounted transmission cooler rotted through and started leaking today, I tried Cummins because I had to go there anyways and they could not find anything, so I assume this is a factory installed item? does anyone know if I can still get it from a dealer, I fashioned a repair(read that "jury rigged") by rotating the rear 90 up and inserting a copper 1/2" id tube sweep 90 to it and ran 5/8" heater hose up the side of the block right on the cooler itself, this keeps it away from the exhaust, and should last a while, but I like to keep things original when I can... .
